ORIGINAL: wflineman2
The wing tube is out of line, when I measure from wing tube to anti-rotation rod there is 1/8" difference.
Good advice from fw190pilot. This would be my method as well. I wouldn't do any sanding of the wing roots or fuse as these areas are not the source of the problem. Just be sure to try fitting the wings without the anti-rotation rod to make sure it is the wing tube holes that are off.
