BEST PAINT NEED help
Cafeen man is right I used to do auto body work and your best bet is an automotive paint. It will look alot better and will last alot longer than the cheap old rustoleum. It will be a little bit more expensive and as long as you use a good respirator than you will be o.k. Just make sure before you paint it if you use an auto paint that you scuff the surface of it up good if it is plastic or fiberglass or the paint will not stick very good. You can use a grey colored scotch brite pad, your local automotive paint store will have these. If you have any other questions about using auto paint then email me.
