RCU Forums - View Single Post - s/m 1/6 f16 in my hot little hands!
Old 12-20-2007 | 11:24 PM
  #247
AndyAndrews's Avatar
AndyAndrews
Default RE: s/m 1/6 f16 in my hot little hands!
Problem with alerons on wing. The hinge is splitting. In order to get the required 20mm throw the tension on the hinge is spitting it. Has anyone else run into this and if so what was your fix? This is a huge problem and I can see the aleron completely splitting and comming off in flight given enough up and down movement. The other wing did not do this.
Anton I think this needs replacing. The more I try to fix it the worse it gets.
