Old 12-21-2007, 06:47 PM
  #32
Kmot
My Feedback: (24)
Kmot's Avatar
Default RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
The engine is now almost completely disassembled. Some things of note:
The master rod needle bearing is made in Germany:
The main rear bearing is an NSK made in Japan:
The front main bearing is no name, but is a rubber sealed 6000RS:
The master rod capture bolt is left hand thread:
Some miscellaneous photos for anyone keeping a reference file:
This is a stand I made to keep the cylinders, pistons and rods, and linkpins organized:
The cylinders have a permanent liner, that is pinned. The steel liner then slides into it, and is keyed on the pin:
To be contined...
