ORIGINAL: FalconWings
Has anyone tried spinning (Flat spinning) without ailerons? Is this possible? You normally require Rudder, Elevator and some opposite aileron to keep the wings flat.
Can you do this on elevons?
other then roockie's with thrust vectoring and the occasional stalled out F-4 I've not seen that many other jets flat spin, it's a bit difficult to recover from with no prop wash or vectored thrust and takes allot more altitude to do so.
