RCU Forums - View Single Post - DS75H servo replacement and setup?
Old 12-23-2007 | 07:39 PM
choppersrule
Default RE: DS75H servo replacement and setup?
Torquestar,
YES, you can do that. Turn the gear with broken teeth 180 degrees from where its at.
Also, with any new heli on the market, parts are gonna be hard to find for awhile. Try to google the part number.
Best of luck,
Dave / Choppersrule
ORIGINAL: Torquestar
Unfortunately the gears were different. not by much, but any variance is going to screw things up.
Doesn't look like he's expecting parts to come in until the end of january.
I don't know how much of gear with the missing teeth is engaged during movement so I might try turning it so the broken side is opposite the meshing gear.
i'll also start checking online for suppliers with parts in stock.
