RE: Swany Mojo 40 ARF?
A 40 or 60 size Dubro wheel works great. You can just leave it castering as the rudder is large enough to turn the plane around without a problem. Also, solder washers onto the tail wheel wire to hold the wheel in place instead of wheel collars and you'll save a little weight.
