RCU Forums - View Single Post - Flybar mod question
Old 12-24-2007 | 11:06 PM
evdreamer
Default RE: Flybar mod question
Your right this mod allows you to adjust the flight characteristics unlike the stock flybar. I just used the stock flybar then cut off the u shaped part then put two CP Pro weights on it. This thing is a beast inside. Almost hit some furniture because I almost couldn't stop. Right now I set the inside of the weight to the outside plastic ball on the flybar to 47mm.
