RE: Flybar mod question
evdreamer,
I ordered some XTREME aluminum Flybar hubs from Michael at USHOBBYSUPPLY.COM and inserted and glued c.f. rod the right diameter, then used heavier than stock bullet weights (can't remember the heli they are used for).
My flybar is 5mm shorter (each side) than stock which prevents strikes, but because of the slightly heavier weights, behaves exactly the same as the stock flybar. I can slide the weights to give Me what Solo was talking about.
Everything has to be a mirror image! What You do on one side, the other side has to be the exact same; distance, weight, trueness.
The flybar I mentioned is totally unbendable, and I haven't broken it yet and I get pretty wild, sometimes. Have had it for months now, and all my helis have it now.
Looks cool, too.
Gary
