ORIGINAL: So Cal Nitro Basher
Also i just realized my friends on/off switchquit turning on, even if you would turn the switch to the "on" positionit wuld not work, the only way he could get it to work was to shove it "on". And it would not stay on, well my switch seems like it is doing that, cause i turn it on and it turns off when i hit a big bump. What is wrong with it? A friend said it might just be dirt in the switch. but i dont know what it is....
yeah, it is dirt in the switch, hold it upside down, and move it back and forth a ton to disloge any dirt... and then hold a vacume cleaner nozzle over it and do liewise, here is a tip, take a sandwitch bag, cut it down smaller, and rubberband it over the switch, that way dirt can't get into the switch, yet you can still shut it on and off
the 2 holes you see in the pic are the buggy mount locations
