I would check the spindle to see if its bent (shaft between the blade grips) and then the main shaft. Another thing to check is tracking. If you know that its the rotors that are causing the problem why not replace them? Also duct tape, as great as it is, isnt really suited for balancing rotors, I use electrical
. If all elese falils I would check on the esky forum on here.
