RE: Introducing the NEW Aeroworks Pitts Python ARF QB!!!
Other than the washers I just added, I only used the 2 1/2 inch standoffs. With the washers added to the right side, it looks perfect against the dummy radial, just about 1/8 clearance all around. I'll probably have to either add additional washers on all 4 corners or use a little rudder adjustment... we'll see how bad it is when it gets in the air.
