RE: new nascada build problems...
MY car was going faster in reverse than in forward. this happens because all "normal" cars have differential gear on the right side, the Nascada has differential gear on the left side.
Solution: adjust your timings
if you have a motor with locked timings you are screwed you'll need ether to change the motor or the car
I changed the car!!!!
