RE: FORMULA 560 CANOPY GLUE/ A QUESTION???????????
560 is the best way to attached your canopy. As mentioned alcohol wipe your fuse and wash the canopy with water to remove any residue or oils from them. Use no more than needed and you may need to tape the canopy in place while the glues dries, usually overnight unless you have a very good fit. The PFM type glues are simply messy for this application.
