RCU Forums - View Single Post - how to maiden
Old 01-09-2008 | 02:25 AM
ram3500-RCU's Avatar
ram3500-RCU
My Feedback: (221)
Default RE: how to maiden
HAVE A FLIGHT PLAN of 10 minutes or so, including things like take off procedure, trimming maneuvers, practice landing approaches, and landing procedures. If you have a plan, you will be more engaged and less nervous.
I always have a friend with me for maidens. Two sets of eyes and ears.
Prior to engine start:
1- check the CG
2- fuel the tank (sounds crazy, but......)
3- Do your 'walk around' of the plane and make sure all is assembled and tight
4- power radio gear and check for correct and free movement
5- range check
6- check radio for all switches in correct possitions
start engine
after engine start:
1- warm up for a minute or so
2- check for proper throttle response and take the time to make necessary adjustments
3- range check
4- check radio switches again
take off into the wind
I use expo to reduce the likelyhood of overdoing it till you have a feel for the plane.
