Thanks Neil!
I had time to work on the engine install today. I used the left over 1"x1" hard point
mounts from the kit and milled them to 2.5 degree angle. I mounted the engine and
tack glued the ply blocks in place.
I have temporary aluminum spacers installed for the fitting. Once I have everything
checked out I plan on turning permanent aluminum spacers.
I will be using 5mm mounting bolts with locking nuts for the engine mount.
I have the cans swapped, left for right in the picture... Just an idea I had for a second.
ORIGINAL: flyme2dmoon
Looking great, Kelly!
