RE: Byron Corsair Build
Thanks guys for posting. Spent a bit of time working on the rails, drilling and mounting the gear. This will all be put together inside the fuselage. I thought that rough aligning now, would save me time when I actually install the formers. I also removed the plywood at F3 for the landing gear strut, before it is installed. Still more to do before I glue it in. I was thinking on using GOOP glue to secure it all, then glass it over after it is set. I have posted a few pictures.
Craig.
