RE: PAU 36% Edge 540 Assembly
Now it's time to add more sweetness, the DA-100. As mentioned before, the firewall is pre-marked so you'll just need to center your motor in the "+". Take a ruler and draw a line across the entire firewall for the thrust line and offset center line.
I drew out the template and taped it on the firewall as shown and drilled the holes for the 1/4-20's. We'll be providing a template for the DA-100. You will need 1-1/4" standoffs for the 100, and four 1/4-20 x 2-1/2" long. Now that I have the motor mounted, I'll mark the locations for the fuel line and throttle push rod remove motor and drill those locations and reinstall motor.
