Well, here goes. After a couple of weeks of waiting, the *huge* box finally turned up
After a quick inspection, I'm very impressed by the quality of the contents. The wings are both pre-joined with the ailerons hinged with metal hinges. The rudder is also already hinged to the fin. The covering is *proper* heat shrink type covering, as opposed to the sticky-back shelf-paper style stuff on some of the cheaper models out there. The cowl is a high quality fibreglass job which has already been painted, as are the wheel spats. The supplied hardware pack is very good, with metric screws etc with decent heads on them. Absolutely everything you need to complete this model is there, right down to the pilot figure and the bright red 70mm spinner. All I'm going to have to do with this model is throw my radio gear and a bottle of glue in the box and shake it up I reckon
