RCU Forums - View Single Post - what do yous think of it
Old 01-15-2008, 01:52 AM
paechy
Default what do yous think of it
I was looking on some forums and i come across this buggy i had a read about it and i wanna now what yous think of it.
FEATURES:
Chassis: 3mm 6061-T6 Aluminum Chassis; Front and rear Aluminum chassis braces
Suspension: Front Pivot Ball, Heavy-Duty Suspension Arms, Front & Rear Sway Bars
Shocks: 13mm big bore shocks with 3.5mm shafts and 1.4mm pistons
Engine: .26 Vertex drill start engine
Exhaust: Polished Aluminum Tuned Pipe & header
Radio: TeamVTX 2-Channel AM Transmitter and Reciever with High Torque & High speed Servos
Transmission: Single-Speed; 4WD; Full Bearings
Wheels: White Spoke wheels
Body: Pre-Painted Body w/Flame Designs (blue/orange or red/yellow)
Gears: 14T clutchbell, 46T steel spur gear, spiral-cut steel ring/pinion gears.
Clutch: 3-Shoe Aluminum
Fuel Tank: 125CC
INCLUDES:
Assembled Ready to Run TeamVTX buggy with .26 Size Engine & Radio System, Pre-Painted Body, Pre-Mounted Tires on White Spoke Wheels, Instruction Manual and Decals, Hex Wrench Set, Cross Wrench, Drill starter.
REQUIRES:
12 AA batteries, 6 cell 7.2v battery & charger, Glow igniter, Fuel Bottle, Glow Fuel.
SPEC:
Width: 315mm
Height: 490mm
Track: Front-306mm, Rear-308mm
Wheelbase: 325-330mm
Gear Ratio:11.71:1
Weight: 3.3kg
Gear Ratio: 11.71:1
