ORIGINAL: Prop Nut
I purchased a G62 as I wanted to turn a larger prop for scale looks.
Hi David,
Why you don't you go to use the Mick Reeves reduction drive now you have the G62? Then you can turn a almost scale size prop! ( 28"-30" ) The G62 with the reduction drive is also a verry compact unit that fit's prob. easily in your cowl.
Your plane is looking great [sm=thumbup.gif]
Teus.
Second picture is the drive unit installed in the 1/3 Reeves Camel from Ralf strutter. First picture is from the Reeves website.
