RE: PAU 36% Edge 540 Assembly
Back to some more pictures.
I've now installed the throttle servo and push rod. You can also see the fender washers and lock-nuts used to mount the motor. I've also drilled a hole for the fuel line and added a rubber grommet. I should add that this type of servo arm is not necessary for the throttle and a good nylon one works fine. This was for mock up as I am still waiting for the throttle servo and cantisters for the 100. Ball links for the motor are 2/56 for 4/40 rod.
Ken
