Fun Factor Rally - Springs and Droop
Hi,
Does anyone know if there are alternative springs for the FF Rally (harder/softer)??? If so, part Nr.s would be great.
If not from CEN, are there any others that fit? HPI or others?
Also, when I lift the front or rear axles off the ground there is no downward movement of the wheels/control arms - that means absolutely 0 Droop. I've tried messing arroung with the preloads, shock positions, etc with no effect. The springs just seem to be so stiff that there is no static compression. Is this normal, or am I missing something?
Any experiences would be great.
Cheers
