Old 01-19-2008, 06:52 PM
jfetter
Default RE: Sebart Angel S Evo 50E
ORIGINAL: eoinjoc
Anybody have any trouble getting the canopy off. I have split the edge trying to release the magnets...and the only way it appears to work is if the front tongue is removed and lifted from the front.
I 'm not sure if I can lift from the back when the cowl is in place
Eoin
Make sure when you mount the cowl you hold it UP tight to the bottom rather than tight down, this will leave room to remove it. As for the magnets, they are strong, I usually wiggle 2 fingernails under the top before I gently pry it up. I suppose if they are too strong you could add a layer of foam tape (thin) so they don't touch but you should get used to it...
Jack
