ORIGINAL: slayerphonics
Go with the Hyper or the 8ight
The servo problem with the 8ight is not a servo problem its the linkage setup on the throttle.. people don't set up there linkages right and EPA so it blows the servo... Its not a problem with the truck its a user problem
It definately is. If you don't set your EPAs properly you're going to kill any servo.
