ORIGINAL: splug
Only salt water here as well but my WH Mag 57 handles the rough stuff well just that I have found the stock prop to be inadequate. I was also suprised to find that the 'isopad' that contains the drive shaft had come loose after only 2 times in the water. I think some spilled gasoline somehow caused the glue holding it to the hull to seperate so now I am more careful to mop up spilled fuel asap.
splug
dude my iso-pad liftted also casued me alot of parts and money. tony says to use ge silicone 2 but that stuff has been not holding up. tony said he called ge and said that he has been having trouble with the product. so i used blue rtv gasket maker to hold it down it holds like iron try it.
