RCU Forums - View Single Post - The Perfect Drift Setup for a TT-01D ??
Old 01-22-2008 | 05:35 AM
verb
Default The Perfect Drift Setup for a TT-01D ??
Hi guys. I've recently purchased a TT-01D Subaru WRC kit, and was wondering what parts/areas I need to complete a perfect build of a RC Drifter. To each his own, so I'm asking everyones opinions on what I do need from the list or what I don't need from the list or what I am missing from the list. Please if you can if you're suggesting a part I should get, to give me a brand name so I can also research on that.. Thanks! Hopefully by then I can get a feel on what is most important and what I can drift without. I've read the TT-01 upgrades should be but not for a TT-01D so I'm not sure what to expect. Thanks for the help in advance. Here we go..
So far this is what I've managed to decide on getting.
Battery: Venom 6-Cell 7.2 3000mAh NiMH Stick [$24.99]
Battery Charger: Venom Racing DC Multi Charger, 7.2v & Receiver Packs [$15.99]
Tires: (already included in TT-01D)
Alternatives for Tires: 2" ABS piping > PVC piping
Oil filled Shocks: (already included in TT-01D)
Ball Bearing Set: Tamiya Ball Bearing Set TT01 (already included in TT-01D) [$18.99]
Shaft: Tamiya Aluminum Propeller Shaft TT-01 [$6.99]
Motor: Tamiya RS540 Sport Tuned Motor 49/62 (already included in TT-01D) [$20.59]
Radio: Futaba 2PH 2-Channel AM/1 S3003/1 MC230CR [$79.99]
Motor Mount: Tamiya Metal Motor Mount TT-01 [$7.99]
ESC: (already included in TT-01D) decided to keep stock *thanks DriftProjectR! until I get a better motor to match it with*
Still havent decided items.
Radio batteries: 8 AA size rechargables (any recommendations? fyi: energizer failed me already )
And for the parts I'm not sure I will need as much as I'm supposed to ???
Aluminum Steering Arms
Aluminum Steering set
I've also read about locking diffs. It seems like I don't necessarily have to do this in order to drift.
correct me if i'm wrong..
In a nubs point a view (which is me) or someone who is just lazy to learn without locking the diffs (which is also me): Lock the rear = Driftable.
as opposed to..
Someone who is patient (which I hope to be) and actually master the drifting technique without locking any diffs (which I also hope to be): No diffs locked = Driftable.
Please no flaming.. Thank You [sm=72_72.gif][hr][hr]
