RE: AK Models F16 Test Build/Fly Prototype Project
[X(] Very good Ron love to hear that for sure ... is it a 55SX or 55AX? ... BIG guess at this time that it may be in at 8 Lbs+ but less would be very cool.
Nice part about this build is I can almost leave the power plant choice till the end... As the F1 has been pre drilled for .60 to .90 size mount and I am going to be able to use a smaller mount with out interfering with the above holes ..so.. if need be I can change up to a bigger engine at any time .. as for the cowl it is remove able and can start off with a smaller hole and be expanded to accommodate the larger engine as well.
Just starting today laying up the fuse.
