dual elevator servos question
Hi guys, I have a Futaba 8U super and I was wanting to ask if the best way to set up dual elevator servos is using the "ailevator" programming and using channels 2 and 8 on the rx ? Ive never had a plane that had 2 elevator servos before so I wasnt quite sure how to do this. And is there a negative to the above setup, if any?
Its going on a skyshark christen eagle arf. If I am off base here , can you recommend a better way to do this?
Thanks very much!!!
John
