Rx21p5 Engine Tuning/starting Problem
have you taken out the glow plug and seen if it is bad? this is a common occurance when breaking in engines. Also make sure your glow igniter is good.if you had it running for 5 tanks I doubt its a tunning problem. Also if you keep on turning it over the engine will get flooded making starting almost impossible.
