RE: Servo problems on the b400
swash type doesn't help with a servo that is intermittent - either you bound it up when putting the gears in, or its buggered
all these servo gear replacements on the 400 !!! - uncanny that my tags haven't eaten a servo yet, knock on wood - could it be a manuf issue with the earliest builds the best?
as i rebuild the b400 to scale, and all the serious detail work that entails, i'm wondering if i should just change out the servos now and get it over with - if i had some handy bucks i'd do that without thinking
i never busted a servo on the trex either, so that does make sense in a weird way
edge
