RCU Forums - View Single Post - Here's A Simple & FREE First Foam Build Plan! (Part 2)
Old 02-04-2008, 02:35 PM
LlamaFragments
LlamaFragments's Avatar
Default RE: Here's A Simple & FREE First Foam Build Plan! (Part 2)
Fisher,
It cuts foam reasonably well. The thing with the tension on it is that you just have to over-tighten it to begin with, and then it will be at a reasonable tension to cut with. For some reason we couldn't find a single spring in Home Depot...
Tonight I'm going to cut out the rest of the template I was working on and maybe start cutting the wing.
