RE: Dynaflite dual elevator servos
Which transmitter will you be using?
With servos rotating in the same direction (standard Y harness), getting identical movement of each elevator half can become a real nightmare (if at all possible), unless somehow you can "mirror" each pushrod location and travel path.
If you radio can do the mix, with the horns at 3 and 9 o'clock...it's a done deal.
