RE: Cutting parts from plywood
I have both scroll (two actually) and a band saw. I usually cover the backside of the plywood with masking tape to help prevent splintering. After the part is cut to shape, a belt and disk sander works well to finish the part. At the end, remove the tape and use the part.
If you're going to build, tools are your friends.
