RCU Forums - View Single Post - LED's & Runtime
Old 02-13-2008 | 04:51 PM
gnd2
Default RE: LED's & Runtime
If the LED's are in parallel, you should be able to simply remove one which will cut the current nearly in half and get you almost 2 1/2 minutes of flight time back (based on your estimate of them decreasing your flight time by 5 minutes). But they might be in series in which case I think you're SOL.
