Well my day did not go as planned. My motor was still so tight my bump box would not start it so I could not run it till I go home. Finally got it started and ran a tank through and that Picco is a beast!! Only issues I had were the servo saver spring is WAY TOO SOFT. I have it turned all the way up and my wheels still go a little straight on acceleration. Guess I will be getting the mugen spring!
Also after the next tank it stalled the my clutch bell was wobbling, thought my bearings went bad but when I removed the bell the bearings were fine. The clearance in the bell for the bearing is a little too big and wollowed the hole out some and wore it out. Put another bell on it and it was nice and tight. Still have to run it some more to loosen up the motor as even after 7 tanks I still have to heat it up. Seemed to handle really well and smooth from the time I have driven it
