6060i question
I am new to RC cars and I have a few questions about this charger and LiPos. I have seen a few post claiming this charger (50 watts) 6 amp charge rate will not be enough for big packs. Can someone set me straight to see if I understand this right?
If I have a 2S 3000 mah (max charge rate of 2c), I could charge this at 1C (3 amps) or 2C (6 amps)?
If I have a 2S 6000 mah, I could only ever charge it at 1 C (6 amps)?
If the above pack were drained, it would take about an hour to charge it?
How safe is it to run chargers at their max rating?
If I get packs over 6000 mah, I will have to charge at below 1C which means it will take longer.
Is there some mah limit to what I can charge? I can charge a 10,000 mah but it will take some time.
It also seems that, in general, you can charge Lipos at a faster rate than NiMH.
If I am wrong, can you explain why please?
Many thanks!
