ORIGINAL: Panzerfaust77
ORIGINAL: brel
ORIGINAL: brel
I find it easier to put the battery in with the battery's power connector end towards the rear of the Tiger tank, as shown in the picture
Cheers but your power cable is waaay longer than mine so I cant' do that.
I took the tank apart and desoldered the wires from the switch and PCB undid the knot and resoldered the wires. Because the battery in the photo is from an old rc car that no longer works so I had to lengthen the tanks wires.
the wires on the black battery are shorter than the wires on the stock HL battery as shown in the picture, but since I lengthened the power lead I have moved the main power switch in to the turret
Yikes! You need get an oil-shield over those geas! That PCB is covered with oil [X(]
Guys, Here is one solution!
http://www.rcuniverse.com/forum/m_67..._1/key_/tm.htm
The Blitz
