RCU Forums - View Single Post - BCX Disaster Help
Old 02-23-2008 | 04:49 AM
Crusader23's Avatar
Crusader23
Default BCX Disaster Help
Hi all,
I just purchased a CNC Main Frame for my BCX . Ok here are the problems I encountered:
1. The gears are rubbing against the Extreme Tailboom. Is that normal? Or do I need some special adapter?
2. My servos won't fit, apparently I have a BCX and not a BCX 2, so the servos won't fit right. Can I get a replacement for the upper and lower servo mount? Or do I just eat the cost and get a new frame assy for the BCX ?
3. Apparently the lower servo mount is closer to the lower gear (inner/upper M/R) than the stock plastic frame.
4. Should I just convert this thing to a BCX2?
Any suggestions would greatly be appreciated.
