RE: Info on putting a p-60 in a Yellow A-4
Ah.
Well, you'll probably have remove some of the lower half of the rear of the inlet duct. You'll need the space for fuel. You can get quite a big Dubro in there under the inlet (if you chop it) and forward of the engine. I made some plywood adapters to go from the stock engine mounts to the turbine clamp-mounts so that I could move the turbine a hair further back. I don't know if I have any pics. Which ARF do you have? Which scheme?
