RCU Forums - View Single Post - Rough field wheel pants
Old 03-02-2008 | 07:48 PM
Deadeye's Avatar
Deadeye
Default Rough field wheel pants
Hey guys. I posted this tip in my [link=http://www.rcuniverse.com/forum/m_7166161/anchors_7167367/mpage_1/key_/anchor/tm.htm#7167367]SSE thread[/link] over in Kits, but wanted to share it here as well
I fly off a grass runway, and I love the way wheel pants dress up a plane. So I came up with a way to mount them that makes them more resistant to damage. I attached a paint drawing that should give you the jist. I poly glue 1/8 ply squares to the inside of the scuffed up pant. I fiberglass that after the poly dries. The axle extends into the outboard 1/8 ply to give the outer side support. I use washers to space the wheel away from the inboard side. I use a 6/32 1/4 cap screw instead of a grub screw in the Dubro wheel collar, and of course grind a flat spot for that screw to sit. The inboard ply not only gives more support, but is also used to screw the landing gear to. I've got pants on at least 6 planes in my fleet, and I hve never damaged one mounting them this way.
Hey Minnflyer, if you read this feel free to dress up my caveman drawing.
