RE: Quadra 52 won't run under 3500 HELP
Thank you Rich,, I have a few more steps on the Zama and if they don't work I will order the wab carb.
Interesting though the WT210B carb intake is almost 1/2" compared to the 11/16 on the ZAMA. My current testing is using a restrictor plate to reduce the intake to 3/8 then 1/2". I have found better idle with the restrictor plate and only 200 rpm drop off of top end. Thanks again. Jim
