RCU Forums - View Single Post - throttle arm problem
Old 03-05-2008 | 01:03 PM
CGRetired's Avatar
CGRetired
Default RE: throttle arm problem
Well, cables do flex if they are pushed to the end points (yep, must adjust them properly). But a good suggestion because it does give more flexibility than a stiff rod does, except for when there is a ball socket at the end of the steel rod.
Somegeek.. did you ever fly that thing? It's to clean!!!
CGr.
