I just got a gallon of Byrons Gen2 20% nitro 12% lubrication. This stuff is crazy. I ran a few tanks last sunday and it did great. No retune was need really it was just a little richer acting...a little. I ran about 4 tanks tonight through it and it did great again. It was even more rich acting though. Tonight I noticed my temps were way below what they usually run too so I leaned it a bit on the hsn and it helped. I got my temps around 200 and it was hauling ace and had great response all through out the rpm range. I had great smoke throughout as well. My tanks lasted noticeably longer too. When I got home I read the info on the container and it claims a bunch of crazy great things all wich I just described. Has anyone else run this new Gen2 from Burons and what did you notice. It claims to have a great film strength and better flow like it is thinner or something. It also idled way longer with out temps rising, loading or stalling. This stuff seems like it living up to the dream fuel they claim it is. Oh one other thing, I have run 1.5 gallons of Top Fuel 20%, 1.5 gallons of Rich's brew 20% and 1 gallon of rocket Science 20% so that is what I have to compare it to. I think I like it.
Whether you are an experienced Byron customer or you are a first time Byron Fuel user, you are about to experience the largest single and most measurable improvement in car fuels in decades!
Byron Originals has engineered a unique and revolutionary lubrication package that combines a greatly increased flow rate with increased film strengths that enhance performance while increasing lubrication qualities. The new Byron Gen2 lube designs allow greater unloading and expanded power curves through increased flow rates of the same oil percentages — and not by decreasing lubrication. The result: Performance AND engine protection only previously dreamed of.
Increased flow rates and increased film strengths of the Gen2 package produce less heat. Less heat produces a broader and less critical needle setting. Increased flow rates enable leaner needle settings which result in more laps per tank and less pitting for fuel.
Attention current Byron RACE users:
You may find Gen2 will run a little fat at your current needle valve settings. You can expect to set your needle to a slightly leaner setting with Gen2 Fuels.
Leaner operation for substantially GREATER MILEAGE!
Consistently COOLER OPERATION!
EASIER, less elusive TUNING!
ENHANCED FLOWABILITY!
High-Pressure Film Strength leaves engine well lubricated following runs and guarantees LESS ENGINE WEAR than you’d expect from a greasy, high oil content sport fuel!
INDUCTION SEALED BOTTLE eliminates contamination and keeps fuel fresh until you are ready to use it!
Backed by the proven Byron Pledge of Quality and Consistency!
