RE: Introducing the NEW Aeroworks Pitts Python ARF QB!!!
I think I am using the Aux switch for choke. Is it the three position switch by the Aileron D/R switch? I use the gear switch for smoke. I am not currently using the landing switch or the p/mix switch. Do you have to use a three position switch for your conditions switch? I will have to get the CD out and play it and learn a thing or two I guess. I could use a knob for the choke. It would not be so easy to bump as the three position switch. I have hit the choke switch while flying my YAK and went to the middle position which still ran but very rich. Figured it out directly and got it switched back off.
