RE: HS81 & HS55 Overreacting
This can happen, especially with pushrods that run through sleeves. One way to combat this is to maximize the end point adjustments in your radio and put the linkage on the servo closer in and on the control surface mount it further out. This will allow the servo to travel further increasing the resolution which will help minimize centering issue you are having.
Mike.
