RE: Applying Ultracote on Ultracote
Also you could use a tool called Woodpecker to provide access for air to escape between the two films. The Woodpecker makes small cuts in the film. Be careful of your fingers it can make small holes is them also. You roll the tool over the film prior to laying on bottom cover and then use the heat iron.
You can find this on Tower Hobby.
