RCU Forums - View Single Post - flaperons?
Thread: flaperons?
Old 03-11-2008 | 01:23 AM
Cleared2Engage's Avatar
Cleared2Engage
Default RE: flaperons?
The flaperons can also be mixed to go up when the elevator goes up, making high alpha manuevers a little easier by reducing it's tendency to tip stall. Be forewarned, this will also decrease the amount of lift your wing generates, so if you try this, mix sparingly. If you're using Real-Flight 3.0 or greater, the E3D has flap mixing so you can see how you like it.
