BCX2 Outer Shaft Assembly Question
Is there a "step" washer that goes up in the body
between the base of the outer shaft and the bearing
that is mounted in the body?..and if so, does the ridged
side of the washer go up against the inner bearing?..
thanks for any help...John H.
