RE: BCX2 Outer Shaft Assembly Question
Yes-- that ridged washer is important. The ridge goes towards the bearing, and presses against the inner race that turns with the shaft, and keeps the plastic gear from rubbing against the outer part of the bearing, that should not turn. Without the washer, there is drag and wear.
